STEP or IGES?
Hi! I’m preparing to send a CAD file to my manufacturer for a CNC-machined aluminum enclosure. Would it be better to use a STEP or IGES file to send to the manufacturer? The design has some tricky features like internal ribs and threaded holes, so I want to make sure everything comes through accurately. I’m leaning towards STEP, but I’d love to hear what others prefer and why.
Apr 28
Solidworks
Apr 14
I Want to Be a Supplier
We want to produce and sell products using our 3D printer.On the test piece you requested (part number: 281893), the filament you want us to use is PA-12.However, we cannot procure this product. Due... read more
Mar 05
