SLS Nylon 12 Paint Color Options
g
What are the colors available for wet painting, please?
Solved by Nikolaus Mroncz
Hey hi, spray painting you can find under finish, like here:
    • g
    • Admin
      Hi,
      In addition to the colors visible in the Niko’s screenshot our spray painting options actually include a much broader selection. By clicking on the “RAL Classic” button, you’ll be able to explore a full palette of over 200 colors.
    • g
      Excellent, Thank You
