Seeking advice: best CAD file format for multi-colored 3D printed toys?
What type of CAD file should I use for 3D printing if I want to create multi-colored small sculptures (toys)? I’m unsure if STL is the best format for this purpose. So far, I’ve primarily worked with STL files and would appreciate advice from the community to find the best alternative.
Apr 28
Solidworks
Apr 14
STEP or IGES?
Hi! I’m preparing to send a CAD file to my manufacturer for a CNC-machined aluminum enclosure. Would it be better to use a STEP or IGES file to send to the manufacturer? The design... read more
