OD and ID vs OD and Wall Thickness - which is the best method of dimensioning?
Hello All,
I am designing a conical-shaped plastic bushing and am confused if specifying the OD and the wall thickness is better for controlling the manufacturing process, or OD and ID separately, with their tolerance ranges individually specified?
Apr 25
Moulding of a Concave Disk
Best process for small stainless steel tiles
hello, my project requires the production of small metal tiles (approx. 50 mm x 50 mm) for decorative and functional purposes. The tiles need to have sharp, well-defined edges, a smooth surface finish, and... read more
Mar 07
