Apr 28
Solidworks
Apr 14
STEP or IGES?
Hi! I’m preparing to send a CAD file to my manufacturer for a CNC-machined aluminum enclosure. Would it be better to use a STEP or IGES file to send to the manufacturer? The design... read more
I Want to Be a Supplier
We want to produce and sell products using our 3D printer.On the test piece you requested (part number: 281893), the filament you want us to use is PA-12.However, we cannot procure this product. Due... read more
Mar 05
