Moulding of a Concave Disk
Hello everyone, I want to make a disk of 203 mm in diameter, 25 mm in height with a concave curvature of 3.22 mm.
Will this precision be respected knowing that I am not a professional but an individual?
    • Hello everyone, I want to make a disk of 203 mm in diameter, 25 mm in height with a concave curvature of 3.22 mm.
    • Senior Content Manager
      Hello, and thank you for your question! For your disc to be manufactured with precision, it is ideal to provide a precise CAD file (STP) along with a technical drawing detailing critical dimensions and tolerances. Here’s a helpful guide to properly prepare your technical drawing. If you have specific requirements for the finish, also remember to indicate the desired roughness, especially with a concave curvature like yours. This guide can help you better understand the impact of the surface. And it doesn’t matter if you’re an individual, as long as your request is well prepared, you’ll get a precise and tailored quote.
Apr 25
Best process for small stainless steel tiles
hello, my project requires the production of small metal tiles (approx. 50 mm x 50 mm) for decorative and functional purposes. The tiles need to have sharp, well-defined edges, a smooth surface finish, and... read more
Mar 07
