hi, designing a snap-fit enclosure for a small handheld sensor (approx. 60 x 40 x 20 mm), and I need to add structural ribs to the inner shell. The issue is the inner surface is slightly curved to accommodate an ergonomic grip, so the rib’s base isn’t flat. In Fusion 360, projecting the rib sketch onto the curved surface results in weird geometry when extruding, especially at the blend between the rib and wall. Is there a clean way to model ribs on a curved surface that still ensures proper draft for injection molding?
New topic
link  edit  https://www.figma.com/design/YTBLdcjRXWn
Jul 31
Solidworks
Apr 14
t
STEP or IGES?
Hi!  I’m preparing to send a CAD file to my manufacturer for a CNC-machined aluminum enclosure. Would it be better to use a STEP or IGES file to send to the manufacturer? The design... read more
I Want to Be a Supplier
We want to produce and sell products using our 3D printer.On the test piece you requested (part number: 281893), the filament you want us to use is PA-12.However, we cannot procure this product. Due... read more
Mar 05
