Mechanical Technician Student
Hello, I am a mechanical technician student at the professional school of technology in Bochum. If you have anything interesting for the school program or for my future independence, I would be very interested.
I also have to do my technician project.
I would like to become independent and hire a few people who would like to work.
Apr 25
Moulding of a Concave Disk
