Hi everyone, I have a new part I am looking to prototype. I am thinking of 3D printing out of Nylon 12. But there are features that require K7 hole tolerance. Do you think this is achievable by 3D printing? Or should I choose milling instead?
Solved by Nikolaus Mroncz
Hi Jari,
unfortunately we can't print fittings.
Better to choose CNC here.
BR
      Hi Jari,
      unfortunately we can’t print fittings.
      BR
Apr 25
Moulding of a Concave Disk
