Is PA 12 a watertight material?
Senior Content Manager
Is Nylon 12 a good material for applications in contact with water?
Solved by Nikolaus Mroncz
When combined to HP MJF technology, PA 12 is indeed water-resistant. But if you want to be 100% sure that the material is watertight (and not just water-resistant), we recommend you to apply a vapour smoothing finish to the PA 12 printed parts.
    • Senior Content Manager
