Indicate chamfers on technical drawing in sheet metal
Hello everyone, I am working on the design of sheet metal parts. Can anyone tell me how to indicate chamfers on my drawing?
Solved by Pierre-Yves Huet
Hello,
For sheet metal parts, it is good to indicate countersinks/milling in 3 dimensions on the plans and to indicate the largest diameter as well as the angle. For an angle corresponding to a 45° chamfer (the most classic), one traditionally indicates a milling at 90°, which corresponds to the angle of the cone of the milling cutter or punch used.
It is sometimes enough to show only a top view, and to indicate the presence of countersinks by a double circle, specifying ⌵ symbol the external diameter, the angle and the number of occurrences.
For example: "⌵ Ø 19 x 90°" (example here: https://www.gdandtbasics.com/countersink).
    • F
      Xometry Engineer
      Hello,
      For example: “⌵ Ø 19 x 90°” (example here: https://www.gdandtbasics.com/countersink).
      • F
        Pierre-Yves Huet
        Thank you for these explanations!
    • Senior Content Manager
      If you have other questions about the types of hole drilling, do not hesitate to consult this white paper on the subject. It contains all the main reference symbols to use on your technical drawings and common applications https://staging.xometry.pro/fr/guides/livre-blanc-types-trous-ingenierie/
Dec 11
FEA of a welded tow hitch
Apr 16
Mar 31
