How to ensure solid models for load-bearing designs
Hi everyone, I’m designing a structural component for a load-bearing assembly and need to ensure the CAD model is fully solid to avoid issues during manufacturing. What are the best practices for verifying that all points, curves, and vertices are properly connected and that the geometry consists only of closed shapes? Additionally, are there tools or methods to generate accurate technical illustrations from such a model to clearly communicate the design intent?
Apr 28
Solidworks
Apr 14
STEP or IGES?
Hi! I’m preparing to send a CAD file to my manufacturer for a CNC-machined aluminum enclosure. Would it be better to use a STEP or IGES file to send to the manufacturer? The design... read more
