Food contact safe manufacturing
Hi everyone! Which is the best solution to 3D print a food contact and high temperature resistant kitchen utensil for manufacturing purpose? Which material? Which manufacturing process? What about compliance with EU regulation (https://www.efsa.europa.eu/en/topics/topic/food-contact-materials)?
