Finish options for nylon in 3D printing
What surface finish options are available for 3D printed parts made from nylon?
Solved by Nikolaus Mroncz
There are two types of surface finishes available for parts printed with nylon (with either SLS or MJF technologies):
  • Post-processing operations that aim to smooth the surface of the parts, for example, vapour smoothing, bead blasting or media tumbling
  • Colour finishes to better customize the parts, like dyeing and spray painting
Both categories are mostly applied for aesthetic purposes. We have a detailed overview of surface finishes for 3D printing on the website, as well as a page dedicated to Nylon PA 12: https://staging.xometry.pro/en-eu/articles/3d-printing-finishes/ https://staging.xometry.pro/en-eu/materials/nylon-pa-12/
    • What surface finish options are available for 3D printed parts made from nylon?
      Surface Finishes for 3D Printing
      Nylon 12 / PA 12 (SLS, MJF)
