We need to create a stainless steel structure for outdoor use in a coastal environment, and corrosion is our primary concern. We’re considering coated fasteners but need to understand whether thicker coatings provide adequate protection, and if there are thresholds where the benefits plateau. Does increased coating thickness affect thread engagement or installation torque, potentially impacting performance?
Best injection molding plastic for plastic enclosure
Hi everyone, we’re talking about a snap-fit design for a small electronic enclosure that needs to be opened and closed frequently—about 20 cycles per week. The part should be injection molded, and I’m deciding... read more
Apr 16
