Help, I need to reduce vibrations transmitted to the enclosure and improve airflow efficiency for 3D-printed spacers for mounting cooling fans on an industrial control cabinet. These spacers need to provide some damping without compromising structural integrity. Would a flexible material like TPU be the best choice, or would a rigid polymer like PETG or ABS with specific print settings (infill density, layer height, wall thickness) offer better vibration isolation?
Best injection molding plastic for plastic enclosure
Hi everyone, we’re talking about a snap-fit design for a small electronic enclosure that needs to be opened and closed frequently—about 20 cycles per week. The part should be injection molded, and I’m deciding... read more
Apr 16
