ABS vs PC in 3d printing prototypes
Hello everyone, I’m currently exploring options for 3d print durable functional prototypes and I’m choosing between ABS and PC materials. These prototypes will be subjected to mechanical stress tests and environmental conditions. Could anyone shed some light on what to pay attention to while choosing between those options? Any experiences or data comparisons appreciated.
